Wackonerd
Sep 13, 2022Tutor
Question on Nighthawk EX7000 AC1900
I want to make sure - that I can run a CAT6 cable from the original internet WiFi router to this one, and it will act as an extender on the same SSID? Thanks!
Sep 13, 2022Guru - Experienced User
No.
If you hardwire it in, you're running it in access point mode. (or should rerun setup to run in that mode)
Access point mode disables the smart roaming features.
You can set it with the same ssid/password as your router and devices will roam to it based on their own protocols. It just tends to be less efficient.
But the benefit is, when hardwired in, the EX7000 has more speed versus running in extender mode.
So there's pro's and con's to each setup.
Wackonerd
Sep 13, 2022Tutor
Ok - so the connectivity has to be wireless from the other router if you want the same SSID and mesh mode? Just making sure I am getting what I need. Thanks!
- plemansSep 13, 2022Guru - Experienced User
thats a little over simplified.
When its setup in extender mode, the smart roaming features are enabled. So you can use it with the one wifi option/smart connect.
If you set it up in access point mode, you manually set the ssid/password. You just have to make sure to put the wireless channels on a different one from the router so they don't cause interference.
- WackonerdSep 13, 2022Tutor
I appreciate your input on this. Here is my problem. I have an existing WiFi router that is in an office - and there are 2 large warehouse areas that I need to cover. The office is in the larger of the 2 warehouses. The 2 warehouses are connected, but have a major brick wall in between them. I would like to put 2 more access points - one in each of the warehouses - to wirelessly cover them. I was thinking of using 2 of these to do that. The brick wall does block a lot of the 5 ghz signal going into the front warehouse. Find a not to scale diagram of the building below. What would you do?.
| | This back part of the warehouse is 300 feet deep by 150 feet wide
| Office | |
-------------------------------------------------------------------------------------------------------------------------------------------- <- brick dividing wall
This front part of the warehouse is about 170 feet wide, and 100 feet deep
I think you should switch to buying an orbi setup versus using 2x AC1900's.. Either standard or pro orbi.
Reason why multiple.
1. I don't' recommend using more than 1 extender. you can do it, but if wireless, it can cause issues
2. Orbi supports both wired and wireless backhaul (smart roaming still works in the wired setup)
3. You can add additional satellites to orbi as needed for extra coverage.
Basically, it'll simplify the setup and be more seamless. And if you're not needing super fast speeds, you can use the older generation AC stuff. Or you can use the newer AX setup.
