Wackonerd
Sep 13, 2022Tutor
Question on Nighthawk EX7000 AC1900
I want to make sure - that I can run a CAT6 cable from the original internet WiFi router to this one, and it will act as an extender on the same SSID? Thanks!
janetwilson
Sep 13, 2022Tutor
You also can use your Nighthawk router as an extender and a non-NETGEAR router as your most important router. Note: If you installation your Netgear router as an extender (wi-fi repeater), vital routing features like community site visitors control aren't active.https://bit.ly/3BFJqPe
