jba
Jan 21, 2008Aspirant
Question to netgear: wds and wpa
I own a DG834GBv3 router and a WG602v3 access point which I want to use as a repeater. However, even when using the latest firmware, this is not possible, when wpa encryption is selected. I found this...
beisser
Jan 21, 2008Luminary
WG602v3 = WPA supported with WDS DG834GBv3 = only WEP supported in WDS you see the accesspoint is perfectly fine.. the problem lies with the dg834GBv3. wds was a very lately added function and it wasnt even advertised ever. you should probably be glad that the dg834gbv3 supports wds at all.
jba wrote: I own a DG834GBv3 router and a WG602v3 access point which I want to use as a repeater. However, even when using the latest firmware, this is not possible, when wpa encryption is selected. I found this problem addressed in many discussions in this forum. So, my question to netgear is: Please tell me, if there are any plans to provide firmware files to remove this bug? When will the customers be able to use their bought products as expected? Juergen
