jba
Jan 21, 2008Aspirant
Question to netgear: wds and wpa
I own a DG834GBv3 router and a WG602v3 access point which I want to use as a repeater. However, even when using the latest firmware, this is not possible, when wpa encryption is selected. I found this...
jba
Jan 22, 2008Aspirant
fordem wrote: What do you define as "expected usage" for a wireless access point?
A wireless access point is intended to be used to link a wireless network to a wired network - that is it's sole function in life - as far as I know the WG602 does that. Any other expectation on your part MAY be inappropriate.
After reading product data on the german netgear site, I dont know why I should not expect DG834 and WG602 work together with wds/wpa:
http://www.netgear.de/Produkte/Router/ModemGatewayRouter/DG834GB/datenblatt.html
Technische Daten
Wireless:
- WPA2-PSK, WPA-PSK, WPA-802.1x, WEP
- Wireless Distribution System (WDS) mit Repeating- und Bridging-Modi
http://www.netgear.de/Produkte/Wireless/802_11g/WG602/index.html
Leistungsmerkmale
- WPA-PSK oder WEP-Verschlüsselung mit bis zu 128 Bit
- Bridging- und Repeating-Modus
fordem wrote: Yes - Netgear does advertise that the WG602 can be used as a repeater and/or a bridge, and specifies the security modes in which those functions can be used - the inability to handle WPA in repeater mode is documented - should you define this as a bug or is it an inappropriate expectation.
Perhaps a little more diligence on your part should be expected ;)
There may be some hints in howtos that it does not work, but these can only be found, when you really have a problem. Before buying a product, I read what the product description says and I think this is clear (see above).
Besides 'beisser' tells us that the wg602 works with wds/wpa and the dg834 is the problem.
Juergen
