harropenk
Jan 22, 2021Aspirant
Question using the AC750 to connect WiFi signal to an ethernet device
This question pertains to using the AC750 EX3700 WiFi range extender to connect a single ethernet device. We have a printer which needs to be connected via WiFi and we can't run cables due to where ...
Jan 23, 2021Guru - Experienced User
It should use the same IP range as the router. I've ran multiple netgear extenders and they've all used the same IP range as the primary router.
- harropenkJan 25, 2021Aspirant
Hi,
Thank you for your reply. Perhaps I didn't ask my question correctly, but I think your answer doesn't address my problem:
(1) We wouldn't be using this as a WiFi extender. Instead, we're trying to connect a wired ethernet printer to our corporate wireless network. The netgear unit has an ethernet port, which according to directions/specifications can be used to connect wired devices to wireless. Your answer would only address trying to connect a wireless device via a bridge mode. We've actually tried that with a couple of competing devices, and sure enough - they put the printer in a completely different subnet. And .... because those devices routing capability was so low-end, we couldn't make changes or get it into a pass-through mode. Heck, even connecting to our WiFi was kind of iffy - we usually keep the corporate SSID hidden, but the way to connect to the network required a visible SSID. Easy enough, we made it temporarily visible just to connect this (ultimately not viable) WiFi-to-ethernet converter, but all of that could have been alleviated if they just allowed users to type in the SSID.
(2) So again, if using this device as a WiFi-to-(wired) ethernet converter, does the unit change the subnet or does it maintain the same subnet at the WiFi? Is is a router or a hub/switch in that mode?
- plemansJan 25, 2021Guru - Experienced User
I understand that you're not using it as an extender.
But in extender mode, it allows you to use the ethernet port as a direct connection in the same subnet.
I don't know what devices you used prior or how you set it up, but whenever I setup a device hardwired into an extender, it pulls the same subnet as my network.
And hiding your ssid doesn't make it any more secure.
