Kdhasproblems
May 17, 2016Aspirant
R6100 as repeater
Can I use my R6100 as a repeater or range extender with a different router provided by my ISP?
DarrenM
May 18, 2016Sr. NETGEAR Moderator
Hello Kdhasproblems
Yes it should be able to repeat any wireless signal.
DarrenM
- KdhasproblemsMay 25, 2016Aspirant
How do I connect it to my network to do that?
- DexterJBMay 29, 2016NETGEAR Moderator
Hi Kdhasproblems,
You may refer to page 88 of the device user manual linked below.
http://www.downloads.netgear.com/files/GDC/R6100/R6100_UM_11Jul13.pdf
Dexter
Community Team
- TheEtherMay 29, 2016Guru
I strongly recommend not using the R6100 as a repeater. It has a big downside, which is that wireless security must be set to None. If possible, connect the R6100 to the main router via Ethernet. Otherwise, buy a range extender.
