ddantes
Nov 14, 2012Aspirant
R6300 with access point -- port isolation question
My guest wireless network area is located far from the office with the R6300 router, so a wired access point from the router is required for guest access. My office network is connected to other ethe...
ddantes
I apologize for the resolution of the network diagram. I have not configured the R6300 yet. I was concerned, if I used AP Isolation, that the R6300 would lose connection with the WRT54GL. Perhaps I could connect a LAN port of the WRT54GL to the WAN port of the R6300 instead of using a LAN port on the R6300. I would appreciate any recommendation.
