ddantes
Nov 14, 2012Aspirant
R6300 with access point -- port isolation question
My guest wireless network area is located far from the office with the R6300 router, so a wired access point from the router is required for guest access. My office network is connected to other ethe...
jmizoguchi
Nov 15, 2012Virtuoso
AP mode in the router feature uses internet port or use tradition AP setup uses LAN to LAN
if you are going to use for mostly in guest AP mode could hinder the guest usage.
r6300 is for guest only? then look at guestgate.com
