SolomonMan
Oct 06, 2021Tutor
R6300V2 now considering Extenders
All, Sorry for being long winded...but please read on... I am out in the sticks (Rural Ohio) and get 15 Mbps down / 2 Mbps upload by microwave from "local" grain elevators. The closest elevator ...
- Oct 08, 2021
Good luck! I hope it covers all your needs!
I've got an RBK43 kit (plus others) and it worked great for me when I was using it.
SolomonMan
Oct 07, 2021Tutor
PLemans/All,
Ordered the RBK43-200NAR this evening and it should be to me by Sunday.
I also picked up a 4 foot power bar to help clean up power connections to the Router Area.
I never mentioned next to the router is an older Commercial Western Digital NAS (4TB). It was an old work one that was updated to a much larger unit. Also there is a chinese camera system also on the network. Both are direct connects to the router. The cameras are WIFI but the main unit is a direct connect to the router. There is also a Magic Jack and a UPS in the router area.
I will probably install everything either Sunday evening or Monday after work. I will update the results.
Thanks Plemans!
Chris
Oct 08, 2021Guru - Experienced User
