MikeWells
Nov 19, 2020Tutor
R6400 and Linksys EX2800
Trying to connect subject devices. Seems I may have DFS 5G Channel selection problem. Documentation is not clear. Anybody help me out?
Nov 19, 2020Guru - Experienced User
A bit more details would help.
Where are you having issues?
Are you trying to setup using wps or using the installation assistant?
What error is it giving it?
you put Linksys EX2800. netgear makes a ex2800 but not linksys. What extender do you have?
firmware on the router?
Firmware on the extender?
we're not there to see whats going on so you need to be detailed in what process you're using and where its failing for us to better help you.
- MikeWellsNov 19, 2020TutorLinksys extender set program sees 2.8G signal but does not see a 5G signal. Notes indicate that router may not be setup for DFS. Netgear documentation lists DFS channels but they do not show up in my drop down list. I am missing something.My bad. It is a Linksys RE6700 Extender. (Old age is hell).Router Firmware is V1.0.1.62_1.0.41Extender Firmware unknown at moment. Never update that I know of.
