nikopower's avatar
Mar 10, 2021
R7800 Wi-Fi Extender RTecommnedation?
Greetings,
I want to extend my wi-fi signal to the basement and den.  I have the R7800 and definately want to use the router's capabilities.  What extender is recommended?
I also have the R7000 that I can direct connect to the R7800 but plan on using the R7000 for WRT on the same network but without extending.
Thanks
Nick
  • plemans's avatar
    I usually recommend the triband line of extenders. With their dedicated backhaul, they don't take the same 50% throughput reduction the single/dual band extenders do. So they tend to be faster/more stable.
    Those extenders:
    EX7500
    EX7700
    EX8000
    RBS40V (has an extender mode)
    • nikopower's avatar
      nikopower
      Tutor
      Went with the EX7500.  Blue lights all around.  However, I cannot connect to my iPhones.
      • plemans's avatar
        did you connect the ex7500 to the r7000 or the r7800?
        did you set it up using wps or using the installation assistant?
        What modem do you have?
        are you using the "onessid" function and smart connect?
        what error/notice does the iphone give you?
