Mako3
Jan 03, 2019Aspirant
R7900 Nighthawk slow wifi with mesh ex8000
Hello all! So I recently upgraded my Centurylink to 140/20MB/s. My setup is their technicolor C2100T (wifi antennas disabled) to my Nighthawk X6 R7900 that is in "wireless access point" setting. ...
Jan 04, 2019Guru - Experienced User
Have you checked to see if you are connecting to the R7900 on one of the two 5 Ghz channels?
Mako3
Jan 05, 2019Aspirant
Yes, I have done a speed test on all 3 bands. 2.4 only pulls 40MB/s. It's ridiculous, I'm loosing so much bandwidth because it isn't transmitted
- StephenBJan 09, 2019Guru - Experienced User
Mako3 wrote:
Yes, I have done a speed test on all 3 bands.Not exactly what I asked. If the extender is reasonably close to the router, then it should be dedicating one of it's radios for the extender<->router backhaul (that's called "fastlane3" by Netgear. If you can see the radio being used on the R7900 device list, it would show the extender as being connected over 5 Ghz.
I'm wanting to confirm that setup.
