andym56
Apr 21, 2021Tutor
R8000P and EX7700 Access Point Slow Speeds
Originally I used the EX7700 as an extender and it was partly successful. I decided some of my issues might disappear if I used it in Access Point Mode (SMART Connect). 1. The EX7700 is wired to th...
Apr 22, 2021Guru - Experienced User
and what firmware is on the r8000P
andym56
Apr 22, 2021Tutor
The cable modem is the Virgnmedia super hub in cable mode. I've been using that config for many years.
The firmware in the router is the latest version.
Thanks for taking the time to respond, but after two very long and fruitless calls to Netgear support I am returning the extender.
I will look for a different solution to my problems.
I will post a different problem for discussion around the router though (not related) at some point.
As I said, your responses have been appreciated.
ATB
Andy
- plemansApr 22, 2021Guru - Experienced User
Vigin media is notorious for their bridge mode not working properly.
what I'd try as a test (prior to returning extender)
Put the virgin media in router mode. (disable its wifi)
Then connect the R8000P to it in access point mode.
then connec the EX7700 to the r8000P
- andym56Apr 22, 2021Tutor
I am in the process of changiing from Virginmedia to BT, but it'll take a while. They all have their problems, but the business offering from BT is more attractive right now.
Too late for any more actions - boxed and ready to be picked up tomorrow.
Thanks again.
