Baitmaker
Apr 22, 2019Follower
Range Extender AC1200 EX6200
I am running Cat6 cable to an out building from the NIghthawk Router. Wondering if I can patch in the Range extender and use it basically as a switch to connect devices..
Thanks
Christian_R
Apr 26, 2019NETGEAR Employee Retired
Hi Baitmaker - Please refer to page 21 of the user manual for more info: http://www.downloads.netgear.com/files/GDC/EX6200/EX6200_UM_EN.pdf
Note: In access point mode, you can connect your computer or WiFi device to the extender only using a WiFi connection.
~Christian
