Richard75
Jul 11, 2020Follower
Range extender EX6100
I currently have a Netgear Nighthawk AC1900 Smart WiFi Router model R7000.
I would like to hook up a Netgear WiFi Mesh Range Extender EX6100 to it. Is the range extender compatable to this router? Is thtere much diffculty setting it up?
Thank you
Richard75
1 Reply
yes the EX6100 would be compatible with it and pretty easy to setup.
You can set it up via wps (push button) or using the installation wizard
