mrking06
Dec 26, 2020Aspirant
Range Extender EX6110 AC1200
HI Range Extender AC1200 Model EX6110 I have set this up all the lights are green i can connect with my android phone to the netgear wifi link 2GEXT but my andoid box will not connect ...
Dec 26, 2020Guru - Experienced User
What router are you connecting it to?
What firmware is on the extender?
are you attempting setup via wps or using the installation assistant?
mrking06
IThe router is a vodaphone B07669 . I updated the firmware so its the latest version. initially i tried the wps connection but the password didn't work, so i used the assitant.My android box is only 2.4ghz so i set the router and extender accordingly. but no joy
i'm going to return it tommorow as im certain it will not work, thanks anyway.
Chris
