myamaung
Apr 16, 2022Aspirant
Range extender EX8000 not communicate with router
My network down last 3days ago. I thought our internet provider lines down. I called to X’finity and checked with them. Their line is ok and work fine. Later on troubleshooting with net gear router an...
myamaung
Apr 17, 2022Aspirant
1. Security issues mean previous app was not working at all. Can’t login. I deleted and reinstalled new app and register again.
2. Router model R7960P (AC 3600, X6S)
3. I can’t read firmware on extender now.
4.I tried both method of setup.
Extender LED are all blinking and also press factory reset button do not help.
Then tried with WPS still the same .
I followed the Net gear setup instructions.
Anything help will be really appreciated.
Thank you so much for replying me.
Apr 18, 2022Guru - Experienced User
where is it failing in the process?
If you're using the installation assistant, it means you're connecting to the extender and should be able to view the firmware version in the gui.
Details a key, just saying it didn't work, doesn't help us. we needed details on where it failed in the process or what you were doing when it failed.
- myamaungApr 25, 2022AspirantI already mentioned that not communicate with router and my laptop . How do I read the firmware?
How to say detail more than that?
