CiprianoMPA's avatar
CiprianoMPA
Range Extender firmware update
I'm trying to upgrade the firmware on my EX3700 Range Extender.  When I download the file my Mac says that I can't open it.  It's a chk file.  The Netgear website is not helpful with trouble shooting and it says I need to pay for customer support.  What can I do?
  • Hi CiprianoMPA,
                                  You should not open the downloaded .chk file. You need to login to extender using mywifiext.net from a device connected to extender, goto "firmware update" in left, browse the .chk file and upload it.
    • CiprianoMPA's avatar
      CiprianoMPA
      Thank you.  I'm not able to open that site though.  Any idea why?
      • jvasanth1984's avatar
        jvasanth1984
        Virtuoso
        Hi CiprianoMPA,
                                      Try mywifiext.net from a device connected to extender's network. If that doesn't work, use the IP address of extender to login which can be located in attached devices of your router.
