Warscott's avatar
Warscott
Follower
Apr 19, 2020
Range extender for c7100v
  Hello, I am must looking for the best range extender that would work well with a C7100V.  I would want that is very easy to install and use.  I installed the C7100V and got it working by myself, but that is about the extent of my knowledge and capabilities!
thank you.
1 Reply
  • plemans's avatar
    I'm a fan of the tri-band extenders. the problem with standard extenders is that they have to receive and restransmit on the same chip. This cuts throughput (speed) roughly in half and increases latency. the tribands mitigate this by reserving 1 of the bands just for router-extender communication. You still take a speed/latency but its much less.
