RogerFrost
Dec 15, 2015Aspirant
Range extender for iMac and Macbook air wifi
I have a 2010 iMac 21.5 desktop which has an internal wifi router so that I can connect to my ISP from my 2011 Macbook Air 11" in the room immediately downstairs, and another room almost 20m away dow...
- Dec 16, 2015
The concern is with the latter: access to the iMac through the modem connection.
RogerFrost
Dec 16, 2015Aspirant
Thanks yet again.
I checked with my ISP and you are right, no firewall on the Ipstar modem, and they do sell a router with wifi and 4 cable outlets.
I am wondering whether the vulnerability of my iMac you describe is through others being able to access it through the wifi hot spot it provides (which would be unlikely as we are 1km from any neighbours or public access) or through the ethernet/modem/satellite connection.
Anyway, thanks so much for your advice and recommendations.
Roger
TheEther
Dec 16, 2015Guru
- RogerFrostDec 16, 2015Aspirant
Thanks so much. Really appreciated your help and rapid responses! Have a good Christmas too!
Roger
