DavidA1375530
Aug 01, 2024Aspirant
Range extender from an AP
Hi I'm not a tech expert so please excuse my lack of knowledge and terminology... Last year I converted my detatched garage into an office. As part of this we ran an ethernet cable from my r...
Aug 01, 2024Guru - Experienced User
Problem with range extenders is that they need a good signal to rebroadcast. If the signal is sketchy, your rebroadcasted signal will be too.
Something to check into might be a point-to-point system. They are a directional signal that can broadcast long distances if there's a line of sight. They basically function as a hardwired connection. You could use something like that to connect the 2 buildings and then a cheap access point in the 2nd building connected to the point to point system.
netgear used to have the airbridge point to point system but I haven't seen it in stock in quite a while. Amazon is a good resource for them.
DavidA1375530
Thanks for this! Yes, i have heard about these. i assume they are the same as the powerline adapters? However I've read that they have to be on the same electric circuit to work.
I think the new garden room will be on the same electric circuit as the converted garage. Therefore can I use an ethernet cable coming out of the Access Point to plug into the powerpoint box. Then add the second powerpoint box in the new room which will then emit the wifi?
- plemansAug 01, 2024Guru - Experienced User
a point to point system isn't the same as a powerline system.
either might work for you.
I'd try the powerline first and if its to far of a run or to much interference, you could switch to the point to point system.
