MesaDon
Feb 15, 2023Follower
Range extender nighthawk axe11000 tri-band wifi 6e router
Looking for a range extender for my Nighthawk Axe11000 tri-band wifi 6e router. Any suggestions are greatly appreciated. I use it for work, play, and media streaming. I also have 3 Netgear network at...
Feb 16, 2023Guru - Experienced User
12k feet is quite a bit of area to expect to cover. Even the RBKE963 is only rated to 9k with a router and 2x satellites.
And if you're needing more than a single extender, I don't recommend using extenders but switching to a full mesh system.
If you have some place around you with a decent return policy, you can always try the EAX80. Its a solid AX extender.
