jcac0220
Oct 10, 2017Aspirant
Range Extender or Access Point or Power Line
I currently have a nighthawk AC1900 router in my basement. I have a deadspot in a room 2 floors above the basement. I trying to get a better signal in that room and cant decide whether a range extend...
- Oct 11, 2017
For X6S (EX8000), you can setup same SSID/password.
arunkmony
Oct 10, 2017NETGEAR Employee Retired
Hi jcac0220,
With any Range extender that supports Access point mode (with ethernet), you will be able to setup good wifi in your 2nd floor. It's often a good idea to match with your router specs to not lose any additional bandwidth. Since you have a Nighthawk you could get a Nighthawk extender as well in AP mode.
EX7300(Nighthawk X4) and EX6400(Essential Edition) are great wallplugs to use and EX7000(Nighthawk) is a good desktop option. If you are looking for the fastest range extension and continue using the same ssid as router and get good roaming for your devices, you can try EX8000(Nighthawk X6S) which gives you tri-band wifi in access point mode.
