scooter-z
Dec 11, 2023Aspirant
Range extender with Nighthawk s8000
I have a nighthawk S8000 in my garage hard wired to my existing Alta fiber modem. I want to have wifi in the garage for Alexa and other wifi only smart switches. Is there a range extender or some...
Dec 11, 2023Guru - Experienced User
There's all kinds of stuff you could do.
You can hardwiring in either a router or an extender. They just need to be setup in access point mode.
Either would work.
I'm a fan of grabbing a router and using it in access point mode. then if something ever happens to your primary one, you have the backup to use.
- scooter-zDec 11, 2023Aspirant
Thanks,
This helps. The rest of the house has a mesh system from Alta Fiber so I have good coverage in the actual house. . I didn't think a mesh neatwork would reach the garage for a good signal. Any recommendations on a router or extender to use to plug into the Nighthawk switch?
- plemansDec 11, 2023Guru - Experienced User
What mesh system does Alta use? You might just be able to hardwire in one of their satellites or pick up a used one for cheap.
- plemansDec 11, 2023Guru - Experienced UserI thought they used Eero so you might just be able to hardwire in one of their satellites. Pretty cheap option and keeps the mesh all the same
