Timothy88
Mar 22, 2026Luminary
Range Extender(EXS25) Management When Extending Guest Network
I have an EXS25 set up to extend my Guest network and now that it's successfully joined I can not get access to view or manage its configuration via the Nighthawk app or browser. Is there a way to...
Timothy88
Tried both the 2.5 and 5ghz ip address and neither works.
Timothy88
Mar 23, 2026Luminary
I was finally able to get connected and logged into the extender. I'm not sure why but I had to connect via the LAN port on the extender and run through the setup again. It's very odd because the extender was connected to my existing router/network and working. The client light was on and the device I was having trouble with was connected and working.
- Timothy88Mar 23, 2026Luminary
I think I’m gaining a bit more understanding to this and that you need to be connected to the extender as as a connected device and I believe this is due to the device to device communication restrictions on the guest network.
