wadecb
Mar 10, 2024Tutor
Range extenders for 5 acre property
Hi, I have a 5 acre property I want to install wifi security cameras all around and there is a small house about 250 feet from the main house that I want to get as good as possible wifi signal to as ...
- Mar 13, 2024
Looks like the ASK-NCQ1338 is there home internet gateway. Its got an ethernet port on it.
So you could use pretty much any of the mesh systems you choose. You'd simple hardwire the router (from the mesh system) into the gateway. then you'd either put the mesh router in access point mode or go into the gateway (verizon) and put it in modem only/passthrough mode. that prevents a double nat.
If you're looking at having some of these mesh satellites outdoors, I'd look around for a mesh system that has outdoor access points.
wadecb
Mar 12, 2024Tutor
Thanks for the reply. Can you direct me to a Netgear mesh system that is compatible with a Verizon 5g hotspot?
Mar 13, 2024Guru - Experienced User
