jacandjack
Jul 29, 2022Aspirant
Range help!
Totally new to this, so please forgive my ignorance. I've purchased a Nighthawk X6 AC2200 Tri-Band WiFi Range Extender in the hope to reach up to 102 metres from my modem to run security cameras...
jacandjack
Jul 30, 2022Aspirant
Thanks so much -(probably a dumb question) but does the airbridge connect to a 2.4 network as well?
Aug 01, 2022Guru - Experienced User
airbridge is hardwired in. You connect in the "master" that is sending the signal. It sends a signal to the receiver on the other end. That device you connect an access point to.
