wiredtired
Aug 17, 2013Novice
RangeExtender WN3000RP:SSID(s)/ Network Name(s)
Seeking an informed opinion re: Pros & cons of using Setup Option 1 (on MacBookPro with Modem/Router Surfboard 6580) as opposed to Setup Option 2 (which is what I just opted to use) To put it more s...
jmizoguchi
Aug 17, 2013Virtuoso
If you want seamless network use SSID otherwise you can have your own preference to have two different SSID
