wiredtired
Aug 17, 2013Novice
RangeExtender WN3000RP:SSID(s)/ Network Name(s)
Seeking an informed opinion re: Pros & cons of using Setup Option 1 (on MacBookPro with Modem/Router Surfboard 6580) as opposed to Setup Option 2 (which is what I just opted to use) To put it more s...
wiredtired
Aug 18, 2013Novice
"If you want seamless network use SSID otherwise you can have your own preference to have two different SSID "
So just to be clear - are you advising doing just as I did and configuring by using Option 2 (since Option 1 - which connects with WPS - automatically creates a 2nd SSID).
Are you saying that having just 1 SSID is preferable?
BTW:Thanks so much for your always helpful input (I've read thru many threads about this particular extender and find your advice to be really meaningful and informed!)
