wiredtired
Aug 17, 2013Novice
RangeExtender WN3000RP:SSID(s)/ Network Name(s)
Seeking an informed opinion re: Pros & cons of using Setup Option 1 (on MacBookPro with Modem/Router Surfboard 6580) as opposed to Setup Option 2 (which is what I just opted to use) To put it more s...
jmizoguchi
Aug 18, 2013Virtuoso
WPS is method of connecting to existing wireless
SSID is wireless network name.
You choice to make is if you seamless networks uses same SSID do default _ext or simply want two different zone then use SSID
This personal preference and thee is right or wrong which way you go
