wiredtired
Aug 17, 2013Novice
RangeExtender WN3000RP:SSID(s)/ Network Name(s)
Seeking an informed opinion re: Pros & cons of using Setup Option 1 (on MacBookPro with Modem/Router Surfboard 6580) as opposed to Setup Option 2 (which is what I just opted to use) To put it more s...
jmizoguchi
Aug 18, 2013Virtuoso
You do NOT have to use WPS
Download manual at support.netgear.com
You will find how to connect existing network with WPA, WPA2 encryption you have
Also you should able to change your SSID as you wish
It is PERSONAL PREFERENCE".
There is plenty of discussion and tons of people are using SAME SSID as "PERSONAL PREFERENCE" to make seamless
thought it was better to just have only 1 SSID.
And you seem to be confirming that.
I still received a dire warning when I configured to set up the Extender to use my existing SSID without the _EXT.
