mrcovalt
Mar 15, 2021Tutor
RAX120 + which WiFi extender
I just replaced my mesh system with the RAX120 because I couldn't control my Apple devices with the mesh system (my HomePod on one band, my iPhone on another, and all under the same network name, it ...
- Mar 16, 2021
Most extenders have a access point mode (not the very base model versions)
So its basically picking which one works for you.
You also could use an old router and install it as an access point. Or even use an access point.
You have many options when you've got a hardwired connection.
Mar 16, 2021Guru - Experienced User
- mrcovaltMar 16, 2021Tutor
Thanks! I had no idea I could use any router. I still have my old Nighthawk X6 R8000 router around, so I just set it up as an access point and I'm on my way now. Thanks for the suggestion!
- plemansMar 16, 2021Guru - Experienced User
Glad it works for you! A r8000 is a darned solid access point :)
