mrcovalt
Mar 16, 2021Tutor
RAX120 + which WiFi extender
I just replaced my mesh system with the RAX120 because I couldn't control my Apple devices with the mesh system (my HomePod on one band, my iPhone on another, and all under the same network name, it ...
- Mar 16, 2021
Most extenders have a access point mode (not the very base model versions)
So its basically picking which one works for you.
You also could use an old router and install it as an access point. Or even use an access point.
You have many options when you've got a hardwired connection.
Jimzimm88
Nov 05, 2023Aspirant
I’ve actually got a similar question/problem. The RAX120 works great for inside my home but I’d like to extend my Wi-Fi range to the backyard so I can connect a TV through Wi-Fi. The signal doesn’t appear to be strong enough from my router. Is there a Wi-Fi extender that I can use to easily extend the range? ( I fully expect signal degradation but I’m hoping some streaming won’t require too much bandwidth)
