Gadi87's avatar
Gadi87
Follower
Feb 12, 2024
RAX20 seamless roaming
Hi,
I have the RAX20, if I get another one or similar, can I have an Ethernet backhaul and then roam seamlessly while connected to the same SSID?
Thanks
1 Reply
  • plemans's avatar
    No. The RAX isn't a mesh router.
    You could add an extender but if you hardwire it in, it runs in access point mode and doesn't support the seamless roaing.
