hugodelp
Dec 11, 2021Tutor
Rax40 eax20 firmware 1.0.4.102_1.0.1
No test done test compatiblity between rax40 and eax20, new firmware, new bad behaviour. Please solve asap. Mismatch why ?
hugodelp
Dec 17, 2021Tutor
as before the rax40 firmware update break the eax20 link.
so the rax40 firmware is incompatible
plemans wrote:What modem/gateway are you connecting to?
What actually happens? You didn't give us any details on why you think they aren't compatible.
How did you go through setup on the devices?
Dec 17, 2021Guru - Experienced User
This literally told us nothing more. It didn't answer the questions even slightly.
- hugodelpDec 19, 2021Tutor
with the previous firmware link worked fine after firmware update on rax40, the link with eax20 is not working any more.
I'm sure netgear didn't do the required quality test.
i need the correct firmware asap.
it's not acceptable for a leader to work like this
when I go on mapping the router is not shown any more on the map.
generic icon not rax40 icon router.
- hugodelpFeb 08, 2022TutorWhen is the next firmware release for RAX40 ?
Please solve EAX20 this link critical issue.- hishinko95Feb 15, 2022Aspirant
same issue here, downgraded router to previous firmware until issue is resolved.
