wifidoesntwork
Feb 08, 2023Aspirant
RAX40 not working with extender EAX20
I know I had an issue a year or so back where my router firmware was updated and the router no longer worked with the extender. Assuming this was finally fixed I upgraded my firmware as I was having i...
wifidoesntwork
Feb 16, 2023Aspirant
Yes I checked the forums and several people had to downgrade the firmware for the extender and router to work together. When I say loose internet, the router’s wifi connection says “no internet” and only the extender works. If you plug directly into the router it works fine. I can use the latest version for 1.0.3.94_1.0.1. Versions 1.0.4 and 1.0.5 cause the router to have “no internet” via wifi.
