pjd813
Sep 26, 2023Guide
RAXE500 to EAX 15 Extender using same address as the router, possible?
I’d like to push WIFI to an upstairs room. Will this device: EAX 15 Can this device connect to the RAX500 so that the extender will use the same addresses as the router? I see a reference to this ...
- Sep 26, 2023
Yes, the extender will use same SSID name and password as the RAXE has. I believe you can tell the extender to broadcast same SSID name as RAXE or broadcast the SSID with EXT in the name. Up to you.
Sep 26, 2023Guru - Experienced User
Two devices can not occupy same IP address. This is a conflict in connections. So each device has it's own IP address. When an extender gets connected to the router, the router will give it a separate IP address to the extender.
pjd813
Sep 26, 2023Guide
OK…. The setup instructions for the extender references a One WIFI Name feature. This is followed by a display of the main router AND the extender sharing the same SSID names. The wording is unclear. It looks like this is a feature that one would simply enable on the extender. Is this a mesh feature and my question attempting to use the RAXE500 here is a square peg/round hole situation?
- FURRYe38Sep 26, 2023Guru - Experienced User
- pjd813Sep 26, 2023Guide
I also see where I goofed in my nomenclature when I asked my first question. My question related to SSID and NOT to “addresses” like I originally posted. My bad.
Got cha.
Ya same SSID will be used by the extender. It's just repeating same SSID name from itself in the remote location where the extender is placed.
