Lutz_112's avatar
Lutz_112
Follower
Jun 01, 2020
RBK20 SATELITTE
I wish to add an extra orbi satelitte to my current orbi router for more coverage at  home. However, my question is can it be any orbi satelitte or does it have to be the exact same one bought with t...
  • plemans's avatar
    Jun 01, 2020
    no, you don't have to use the same satellites from the kit you bought.
    you can use:
    rbs20
    rbw30
    rbs40
    rbs40v
    rbs50
    rbs50y
    just keep in mind that the 50 series use a wider backhaul. you won't be able to take advantage of that since you have the rbr20 but they'll stil work. just not at the wider backhaul they're capable of.
