speshl4me
Dec 18, 2024Aspirant
RBS50Yv2 my Orbi extender wont reset, turn the lights from white to blue for sync,
I am at the end of my rope with this extender. It has not worked on and off for sometime, sometimes I never get told it is not working. When it stops it has to be taken down and brought in and next t...
Orbisingh
Dec 21, 2024Aspirant
If your RBS50Yv2 Orbi extender isn't resetting or syncing (white to blue), try the following steps: Power cycle the extender by unplugging it for 10-15 seconds and plugging it back in. Press and hold the reset button for about 10-15 seconds until the light starts flashing amber. Check the placement of the extender to ensure it’s within range of the main Orbi router for a proper sync. If it still doesn’t sync, you may need to try a factory reset via the app or web interface.
