Arvandor593
Aug 06, 2022Aspirant
AC1200 Dual Band Range Extenders blocking direct connection
I have installed a pair of AC1200 dual band wifi range extenders. But they seem to be preventing my desktop PC from directly connecting to my broadband modem. I can connect to the extenders, and whe...
Aug 06, 2022Guru - Experienced User
Have you tried setting the extenders with static ip addresses in the virgin hub?
Arvandor593
No. How do I do that?
- plemansAug 06, 2022Guru - Experienced User
You'd have to look in your virgin hub manual
