ChrisL1971
Oct 11, 2018Guide
Additional feature request for EX8000
I' m missing a view option in my EX8000 and would like to know if there are more users that want the same feature or other features. Please support this by the "thump up" or post your feature request...
schumaku
Oct 14, 2018Guru - Experienced User
Hi Chris,
ChrisL1971 wrote:
- Logging options like other Nighthawk routers have eg r7800
Can't see many applicable to an extender - logging is substandard on all Nightgear routers, and virtually not existing on extenders.
| Attempted access to allowed sites | |
| Attempted access to blocked sites and services | |
| Connections to the Web-based interface of this Router | |
| Router operation (startup, get time etc) | |
| Known DoS attacks and Port Scans | |
| Port Forwarding / Port Triggering | |
| Wireless access | |
| Turn off wireless signal by schedule | |
| ReadySHARE | |
| VPN Service | |
| Plex Media Server log | |
| Amazon Cloud backup log | |
| SFP+ log | |
| Link aggregation log |
Borrowed the table from the R9000 - which one(s) you have in mind? GRanted - any authenticated (and ideally also failed) admin access must be logged (Web UI, Genie App).
ChrisL1971 wrote:
- Abillity to select Lower transmit power eg 50% vs 100%
Probably not in place because most Netgear Wireless extenders are making use of all (one 2.4, onr 5 GHz) interface for linking to the master or other mesh devices. For the new mesh extenders with the dedicated 5 GHz radio for the uplink this idea could be feasible. But then, I'm not convinced if this is a smart idea to have on a consumer device.
ChrisL1971 wrote:
- Support a Guest network setup besides the normal SSID like eg a R7800 router can do.
Requested many times. Trouble is that these consumer routers don't have a reasonable guest network implementation allowing proper isolation and/or integration - it's merely a small feature of the wireless radio where another SSID is configured, and a control for the isolation enabled/disabled. Implementing this would require a systematic design change - in my opinion using VLANs, with a dedicated subnet and DHCP [Netgear does not agree - I had a longer and tough discussion with JohnMcH on this subject, both personally and here in the community - the price is the borked and limited wireless guest implementation we have on the routers, on the Nighthawks, on Orbi, and Orbi Pro]. Very unlikely to happen.
ChrisL1971
Oct 14, 2018Guide
schumakuwrote:
Hi Chris,
Attempted access to allowed sites Attempted access to blocked sites and services Connections to the Web-based interface of this Router Router operation (startup, get time etc) Known DoS attacks and Port Scans Port Forwarding / Port Triggering Wireless access Turn off wireless signal by schedule ReadySHARE VPN Service Plex Media Server log Amazon Cloud backup log SFP+ log Link aggregation log
Hi schumaku
I'm Using my EX8000 as a access point maybe that explains a bit :-)
Logging: For WLAN security issues / system trying to access the AP with false passwd. I would like to know when that happens. and which MAC it trying to access my AP.
- limmit Power to prevent the access point from keeping a connection over a longer distance and interfering with other accesspoints.
Hope this explains a bit.
Chris
