MathieuEX8000
Jan 21, 2020Aspirant
Débit faible en ethernet EX8000
Bonjour, Je viens de mettre en place le répéteur X6S EX8000 connecté en wifi avec ma box SFR fibre. l'idée est de redistribuer la connexion wifi sur mon PC fixe, et ce en ethernet. L'appairrage...
Jan 22, 2020Guru - Experienced User
It doesn't mean that the backhaul is the issue. It just means that you've narrowed the problem to either the router or the extender backhaul.
when you setup the device, did you use wps or the smart installation wizard?
What model is the fibre box?
MathieuEX8000
Jan 22, 2020Aspirant
Thx again :)
I tried to use both WPS then Wizard with the same effect.
I really don tget why it s limited either Wifi and ethernet (maybe i have to change the 5Ghz Chanel?).
My box is as describe in the following doc.
