faisalalsalm
Jul 28, 2022Aspirant
eax80 "enable media server" blocked access to both ready storage and admin web
hi all i have eax80 extender its currently setup as access point and have a 4tb usb drive connected to its usb port when i check the "enable media server" box after about 5 - 10 min i will no long...
olympos1625
Jul 29, 2022NETGEAR Employee Retired
Hi @faisalalsalm,
Welcome to NETGEAR Community!
Thank you for reaching out. We are sorry to hear about your experience with the extender. Just to clarify, the issue started after using a new hard drive, Is that correct? If yes, may we know the brand and model? With your old hard drive, you didn't encounter similar issue, is that correct? How many hard drives did you try already and what are the brands and models? Please try downgrading the firmware and resetting the extender as well.
Please do not hesitate to let a know if you need further assistance.
Oliver
Community Team
faisalalsalm
Jul 29, 2022Aspirant
hi
the old 1tb was WD my passport
the new one is 4tb WD my passport
i reattached the old 1 tb and its working fine but i needed more space
i did reset the extender and it didn't help
i will try new one just to make sure i have a 5tb WD element
