VenomAX
Apr 01, 2020Tutor
EAX80 extender disconnects and crashes
I just purchased the AX8 Wifi Extender (EAX80) to mesh with my RAX80. The EAX80 crashes and disconnects every hour. Seems like a software issue. Noted that a new firmware release hasn't happened s...
Tofu101
Apr 11, 2020Star
I've experienced nothing but issues with my EAX80 paired with an RAX200. Persists in disconnecting itself every couple of days. Lousy off-shore support with zero product knowledge butchering the English lanuarge while reading irrevelant troubleshooting off of triage scripts. Netgear products and support used to be top notch ... now just about everything they make is riddled with bugs and their support is abominable!
marcusclaus
Apr 20, 2020Guide
Have A RAX200 and an EAX80 extender.
After installation the EAX80 works ok. I have 2 SSIDs one on 2.4 Ghz and one on 5 GHz on Ch 100 with WPA2 encryption on both wifis. Smart connect is off. One Wifi Name is on. Linkspeed from pc is 1300mbps when connected using netgear A7000 adapter, and things work well.
However, when I then change the EAX80's IP from dynamic från the RAX200's DHCP beacause I think it is conventient to have fixed IPs for the backbone infrastructure components in my network...., to a fixed IP address for the EAX80, the EAX80 goes totally crazy:
1. the 5 ghz wifi starts to drop by itself, and comes and goes...
2. when it shows up and I connect to it, it backs down to link speed 54mpbs
3. sometimes when connecting the pc reports the network supports only an old pks standard...
I do a new smart setup of the EAX80 and it is then back to ok. I try to change its IP to fixed again, and the same problems happens again. I.e. reproducable....
