dcinca
Jun 19, 2022Apprentice
EAX80 slow upload speed with RAX120
Hi everyone, Rax120 and Eax80 with wifi 6 on, 900ish/900ish Mbps download and upload are tested from Rax120. The upload is limited to 50ish Mpbs if the device is connected to Eax80, both wired an...
Jun 22, 2022Guru - Experienced User
Is the eax80 new? Or the RAX?
If so, you could be in your 90 day window of free support.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.
dcinca
Jun 24, 2022Apprentice
They are not new, I just want Netgear know this bug and fix it later. How do I report it?
Thanks for helping.
Thanks for helping.
- plemansJun 24, 2022Guru - Experienced User
About all you can do is post it on here as you did and hope a moderator sees it.
Not sure if its a bug though as you'd think that'd be caught pretty quickly with the rax120 and the EAX80 as they're 2 of the flagship devices (dual band router and extender)
