fadsarmy
Jul 22, 2023Aspirant
EX6410 Only Works After Logging in
I've had this about a year and it has worked flawlessly. Recently, if I move the extender from one power outlet to another, it says "no internet" when I connect to it's network. Just simply by loggin...
fadsarmy
Jul 28, 2023Aspirant
Thanks for your input. I've tried everything including what you suggested but to no avail.
DexterJB
Aug 08, 2023NETGEAR Moderator
We recommend contacting our support team for them to investigate further on the issue that you're encountering. You can always reach our support team via the link below if you need any technical assistance with your NETGEAR device.
https://www.netgear.com/about/contact-us/
You can also call the number below.
1-888-NETGEAR (1-888-6384327)
Dexter
NETGEAR Team
