DeathValley
Aug 26, 2022Follower
EX7300V2 Cannot connect to 5G on the Wifi Router (Netgear R6900P - Dual Band)
Netgear Wifi Extender: EX7300v2 Firmware Version: V1.0.0.146 Netgear Wifi Router: R6900P Firmware Version: V1.3.2.134_10.1.66 Using the WPS setup process per the user guide. It states...
olympos1625
Oct 20, 2022NETGEAR Employee Retired
Hi DeathValley,
Good day!
Thank you for reaching out. We are sorry for not being able to get back to you immediately. Did you by any chance try disabling the Smart Connect feature of the router and try setting up the extender first then enabling again the Smart Connect feature of the router?
I am looking forward to your response.
Oliver
Community Team
