JoeFI
Jul 24, 2021Apprentice
EX7700 has stopped connecting to 5GHZ network
Hi, I've had an XR500 router and ex7700 extender for about a year now. And for the last month the extender won't connect to the 5ghz network. I've tried switching channels and at it connected but aft...
Jul 25, 2021Guru - Experienced User
You're using the "onessid" or mesh function?
If so, that allows devices to move between 2.4ghz and 5ghz.
You can disable it and then choose which band you want it on.
also, the EX7700 is triband. It has 2x 5ghz bands. a high band and a low band. If the one the router is using has interference, sometimes switching which band the router is using from low to high and vice/versa can help
JoeFI
Jul 25, 2021Apprentice
This is what's confusing me, different id's and password for 2 and 5. And smart connect is disabled. Also when I reset the Extender I said I only want 5g network extending but on both resets it ignored my choice and extended the 2 anyway.
- plemansJul 25, 2021Guru - Experienced User
When you uncheck the "extend 2.4gh" it should just set it so the 2.4ghz doesn't default to backhaul if the 5ghz drops.
