ConfusedOneIAm's avatar
May 04, 2021
EX7700 Router Link - Solid red. Poor connection.
I have two EX7700's both with the same settings, both in the same room as the router (setting up)... one has Solid white. Best connection. whilst the other is Solid red. Poor connection. How can t...
  • plemans's avatar
    May 04, 2021
    Did you shut off the other extender?
    Having 2 in the same room can cause issues during setup. I usually recommend shutting down 1 while setting up another one.
