p_wallace
Aug 30, 2025Follower
Multiple extenders
Hello,looking for some help on my home network. First thing is let me say I have extremely limited network knowledge. If I can hook it up and it connects I consider it successful. I do come from the...
Aug 30, 2025Guru - Experienced User
What speeds do you pay for?
I never recommend using more than 1 range extender as they'll drop speeds and increase latency. And the older ones aren't "mesh" so cause more SSID's.
If you're still using old enough stuff that they aren't mesh, I'm betting your gear is a bit older. If it was me, I'd move to a half decent mesh system like Orbi with a dedicated backhaul.
that'd be the triband versions or even quad band. You can pickup used or refurbished last generation devices that will be a pretty rock solid upgrade fo ryou. I've seen the 753/763 for around that $200 and the 853/863 for around that $350. Which are both pretty solid options
